- Lettera Version:Version 1.0.0 (4091)
- macOS Version: 26.5.2
- What were you doing: reading MD file in external tool
- What feature did you use: editor
- What happened: I was receiving errors from 3rd party tool saying it was a bad MD format
- What did you expect to happen: that there would be no MD errors
As mentioned in another post, I was receiving errors reading the MD file. I used https://babelmark.github.io to verify the MD and it pointed to the first position and first line which was a H2 bolded text. I removed the H2 iand it worked. I then went into my original file, removed the H2 and Bold syntax and recreated it via Lettera and the external 3rd party app is no longer giving me an error.
I had it happen to 2 MD files in the same folder and it was the first line with a H1 or H2 set.
Please just treat this an informational message just as something to watch. I don’t edit the files outside of Lettera. I suppose it’s possible that a 3rd party app made changes to it even though they are not editors. Feel free to change the optional tag from Bug to something else as you see fit.
-tom
