HEIC Attachments Not Displayed in Notes
Operation system: Windows
Web Browser: Chrome
What were you doing: I attached a file in the HEIC format to a note and tried to open it.
What feature did you use: Notes with attachments (drag and drop)
What happened: The HEIC file could not be displayed within the note (but it is visible on my iPhone and iPad) → see attached screenshot
What did you expect to happen: The HEIC file should be viewable directly within the note, just like other image formats.
You are right. Currently only Safari supports showing HEIC images. We will explore if we can show them anyway by using a third party library.
Thanks for your response and for looking into this! I actually only have one single HEIC file in my notes. I just noticed the issue and wanted to report it. Personally, I probably won’t need HEIC support in Bear Web – if necessary, I can simply convert the file to JPG or PDF.
