I know I can insert formulas into notes using $ or $$.
There is also a specific BIU menu item to do this on iPhone. But I cannot find the same menu option on iPad, is there something to configure?
Greg
Greg
Here it my iPhone BIU panel with specific Math Formula buttons:
But on my iPad BIU panel I can’t find those buttons:
It’s just me ?
Greg
Okay, so is it just me, or does no one else care about not having this feature?
We are studying where to fit the Mathjax buttons on the BIU keyboard on iPad but mind you can use the $ sign at the moment.
Not just you.
I would suggest having 3 heading buttons is not necessary… But to others I’m sure it is.
But even if you haven’t decided where to put the math button, maybe it should be somewhere at least, even if only temporary?
