Integration with ProWritingAid not working
  • Lettera Version: 1.0
  • macOS Version: 27.0 Beta (26A5353q)
  • What were you doing: Just editing
  • What feature did you use: Composition
  • What happened: Nothing
  • What did you expect to happen: I expected to see the ProWritingAid dingus floating around in the window.
I use ProWritingAid to help ensure my writing is as good as I can get it. The Mac app includes a little dingus that floats on text editing apps. For example:
But when I’m using Lettera, the little dingus is not present.
This isn’t the end of the world, but as I’d love to make Lettera my primary writing environment, the integration is pretty valuable.
