I’d like to use shortcuts to periodically rename some notes based on some date logic. I can determine which notes need to be renamed using shortcuts but do not see anyway to rename the note. None of the shortcuts allow for editing the name. Has anyone solved this?
Did that shortcut above (and below here) work for you?
