Linking to other notes?
Operation system: Windows
Web Browser: Chrome
I’ve tried using the [[ and @ notations but nothing happens - is it a bug, or at the moment it is not possible to quickly link another note in the Web app?
Thanks
I was able to create a link to from one note to another note in bear web. I type >>, then start typing the name of the note I want, and click on it. A link is created.
I’ve never seen this notation - I’ll give it a go. Thanks man!
My mistake. The >> symbol is in Apple Notes. You still use [[ on Bear Notes in the web app and it creates a link.
I think we have found the bug mentioned, but I want to verify if this is the case for you.
We have found that [[ opens the note linking panel, but not next to a #tag.
Hi, now it seems to be working without issues. Thanks!
