- Lettera Version: Version 1.0.0 (3980)
- macOS Version: Tahoe 26.5.1
- What were you doing: Switching from Lettera app to another & back
- What feature did you use: Was editing a note
- What happened: Not sure if this is by design, but when returning to Lettera, if I click on the sidebar to go back to Lettera from another app, it blanks out the note pane and just shows the standard New File, New Folder, Open options. If I can see the note pane, then it does return me to that note I was working on.
- What did you expect to happen: I would expect to be returned to the same note I was viewing, whether I click on the sidebar or note pane. Many times when switching away from an app like Lettera, I can only view a sliver of the app in the background. So being able to click anywhere on the app should bring me back to where I was, not make me remember the title, find the note, and select it again.
