Make Read-Only / Make Editable
Please, could you create a shortcut into Bear for activate/deactivate Read-Only Note ?
I have to turn it on and off with each note, and it’s a pain to go into the menu every time. UpNote uses Shift + Cmd + W, which is really cool, but I prefer using Bear.
Mind you can assign custom shortcuts for menus in macOS. In this case you need to assign a keystroke for Make Read Only and Make Editable.
Yes, I know, but I think pointing out a lack that seems essential for user comfort is more logical. Bear has a Copy Link shortcut with four keys, which probably isn’t used very often, but not to protect documents from accidental modification? I think that would be infinitely more useful. But perhaps I’m the only one, it’s true.
Shortcut
