Bear 2.3.11 is here with new features, fixes, and a little extra polish. ![]()
Read-Only Mode
Sometimes, you just want to read your notes without accidentally editing them. With Read-Only Mode, you can scroll through your thoughts and ideas effortlesslyâperfect for focused reading or quiet reflection.
To enable it, open the â«¶ menu and select âMake Read-Onlyâ. Youâll see a read-only icon appear in the top-right corner. When youâre ready to make changes again, just click or tap the icon and select âMake Editable.â
4 New Themes
Introducing Shibuya Jazz, Shibuya Lo-fi, Everforest Light, and Everforest Dark. Shibuya Jazz and Lo-fi are two similar themes as Dieci with absolute black #000000 background, perfectly designed for AMOLED screens. The Everforest light and Everforest dark are based on the Vim theme Everforest made by Sainnhe, bringing you a warm and soft tone with mild contrast. Check out more themes here: Bearâs themes
Full Changelog
As always, weâve squashed some bugs to keep your experience smooth and reliable. Check the full Changelog here:
coreOS
- Read-only mode: By using the â«¶ menu inside a note > More or Long press/right-click on a note you can set a note to not being editable
- Folding can be toggled for read-only notes by using the Side Actions.
- 4 new themes: Shibuya Jazz, Shibuya Lo-fi, Everforest Dark, Everforest Light
@readonlyspecial search- Fixed editor crash with collapsed sections
- Opening a note while a search is active in the Notes List correctly scrolls you to the first result and focuses it
macOS
- file:// links now correctly open the Finder on macOS recent releases
- Fixed bug preventing attachments of archived notes to be opened
- Shortcut export action bug corrected
- Fixed dictation issue with lists
- Small fix for print not preserving the image sizes in some conditions
iOS
- Images inserted via the iOS sharing extension are now properly synchronized
- Corrected the Backlinks Panel scrolling behavior
- Now notes are correctly created when the Notes List has an active search containing a â-â
- Fixing the search term edit in the Notes List when it contains color-changing special characters
- Properly handling the visibility of the Editorâs left border
- Notes trashed, archived, or read-only donât show the BIU keyboard button on the selection
- Improved the tappable area for resizing images on iPad
- Removed crashes concerning the sketcher
- Leaving the current panel visible in the Editor when switching apps
- The disclosure button in the Backlinks pane is always visible
- Patched issue with text copied from chatGPT
Download Bear 2.3.11 now!
âBear - Markdown Notes App - App Store
âBear: Markdown Notes App - App Store
