Missing Spanish localisation
  • Bear Version: 2.6.5
  • OS Version: iOS 26.2
  • What were you doing: adding a button to Control centre
  • What feature did you use:
  • What happened: Some buttons for Bear are not localised to Spanish while others are
  • What did you expect to happen: given that Spanish is the selected language, all buttons should be in Spanish.
I must add that “Nota de documento” sounds odd in Spanish. Something like “Nota con documento” sounds more correct.
Thanks for reporting this bug. We’ll ship a fix with the next update.
