(Mobile) keyboard shortcut for html comments
Bear appears to support rendering HTML comments already. I’d like a shortcut to place the highlighted text inside <!– comment –> markup, or to create the markup and place the cursor inside it when there is no text selected.
On desktop, the ideal shortcut is CMD + / (consistent with other apps).
On mobile, I think the shortcut could fit naturally inside the </> button submenu.
EDIT: Thinking more on this, it might be Panda where I want this feature more, although consistency/parity between the two would be ideal. It’s most useful to me editing markdown files in a code repository, with a nicer viewer/editor than my code editor provides…
