Archive and Trash now feature prominently at the second and third spot in the sidebar containing the tags list. They really should be at the bottom, below all the tags.
That would split the left sidebar into 3 sections rather than the two we have now. I really don’t see any good reason to do that
The good reason is, quite simply, that less important items should not occupy a prominent place.
I knew that this is your reason. I just don’t consider it as a good one because 1. your criterion is subjective and 2, it causes as I said the split into three sections. In regard that there are no more than three entries before the tags starts I cannot see the benefit. ![]()
The current layout is magnificent and close to ideal, if not perfect. Sections “Notes”, “Archive”, “Cart” should be together in my opinion - because they talk about the same things in different contexts: notes - relevant, archive - irrelevant, but potentially useful, basket - irrelevant and useless. It is not necessary to take out the “Archive” and “Cart” separately from the “Notes”, placing them below the tags.
