Moving item up/down with shortcuts not working
Moving an item (paragraph, line, bullet, todo etc) with keyboard shortcut (option+cmd+arrow) doesn’t seem to work. Choosing the command from the Edit-menu does seem to work.
Version 2.0 (10084)
Edit: It seems I prematurely posted my experience. After experiencing the same behavior in Bear (where it always have worked this far), I restarted the computer and moving items with shortcuts now work in both Bear & Bear 2.
MacBook Pro M1, macOS 13.1 (22C65)
