When using the Cmd+Option+Arrow keyboard shortcuts to move the current line up or down, I wish that Bear would scroll the note as needed instead of having the selection go off screen. Ideally it would keep a couple lines visible above/below the current line as well, so that I can know when to stop moving the line if I’m moving it a long distance.
Example: I have a long to-do list that is broken into sections. I want to move a task from one section to another section (which is off-screen) so I hold down Cmd+Option+Down to get the task into the proper section.
(I love that I can move lines with the keyboard, btw. That was one of my must-haves/dealbreakers when shopping for note apps.)
