depending on the situation I like to use different note sorting settings…
- for example when I’m looking through all my notes I like to sort by modification date so my most recent notes are right at the top
- but when I navigate to a set of notes by the tag menu I almost always have them sorted by title
since I am constantly switching back and forth between these views, going through the multiple menu clicks needed to change the sorting setting becomes tedious, and so my question/request is…
- is there a way to have bear save the last used sorting preference on a more specific basis vs just an app wide basis?
- or (more likely) is there a keyboard shortcut I could use to quickly switch between the sorting options on the fly?
