Custom sort options per tag
Hi, I’ve just started using Bear as my default note taking app and I’m over the moon with it.
It might not be a big thing but one thing I’d love to see is the ability to sort the notes list differently on a tag by tag basis. For instance the main tags, sort when updated. For others sort alphabetically and so on.
Keep up the excellent work with Bear and I look forward to seeing what’s in store in future releases.
Kind regards,
Jack
You can pin your main tags. It’s not the same, but in this way you can make your first tags on top of your list.
I think he doesn’t mean the sorting of the tags inside the left pane but the sorting of the notes inside the notes list. Currently the sort order is a global one and isn’t dependent on which tag is shown in the second pane.
As far as I am concerned, I would like to sort all sections (All, Untagged, Today …) independently. However the sort order applied for one tag could be applied for all other tags to avoid mess.
I understood and I agree. OK, thanks for the reply.
Would love this too!
+1 for this feature: per-tag custom sorting
