Hey everyone, today we want to discuss Panda with you: weāll outline our vision, showcase some preliminary screenshots, and then address any questions you may have.
Please note that nothing is set in stone at this stage, and weāre open to considering all feedback and suggestions you may have.
Our aim with Panda is to serve two primary purposes:
- Provide a streamlined Markdown editor for quick document creation: simply open a file from the Finder or another app, make your edits, and youāre good to go.
- Offer a more traditional ālibraryā setup: create workspaces (single or multiple) containing folders of Markdown files that can be edited, searched, and interconnected.
These functionalities are not mutually exclusive and can be utilized simultaneously, depending on your specific needs.
While Panda will draw inspiration from some features of Bear, weāre committed to ensuring itās not merely a āfile-based Bearā. Weāre striving for Panda to carve out its unique role and identity.
Panda will boast deep integration with the Finder/Files, facilitating collaboration via shared file systems and seamless interaction with other apps that work directly with files.
While tags may not be featured (or at least not in the same capacity as in Bear), backlinks could potentially play a more prominent role.
Below are some initial mockups weāre currently assessing with the team. These are not finalized in terms of details, but they serve as a starting point for visualizing what Panda could become.
Now, we invite you to join the discussion and share your thoughts. Your feedback will shape Pandaās development and ensure it meets your needs. Letās build something great together!
