Panda Sneak Peek: A Work-in-Progress Markdown Editor and Library 🐼
It is obsidians way too. You create a note from hotkey (or from icon in the sidebar) and that opens immediately the note (after being placed directly under the workspaces root folder) inside the editor without any disturbing dialogue. I think we mean the same.
Furthermore obsidian uses the very first line of the editor for the name of the file. A new note in obsidian always starts with the name ā€œUntitledā€ which is selected. So you can either directly start typing the name of the file OR you just hit ā€œenterā€, the name ā€œuntitledā€ remains und you continue with typing text. I consider that as ideal.
Yeah, but again, that’s not an issue with automation. Simply have the file be renamed automatically with your first few captured words to know what’s what. :slightly_smiling_face:
I am not sure what you mean
Create a quick entry macro working more or less like this.
  • Pop up text field, enter Some random thought inside which is very important and dear to me.
  • Have the macro save the file using as filename, say, the first four words of the text.
  • You now automatically have a file named Some random thought inside with no need to name your quick entry file.
Sorry, I am not able to create a macro. I even don’t know what a macro is. :sweat_smile:
I just meant something simple what probably @roar also meant. That the first line of the note is dedicated for the name of the file. See the screenshot from obsidian:
I advocated for that because it is an easy way: either starting with the name inside the note after creation OR just hitting enter to continue in the note and leaving the note unnamed. See video for illustration:
Edit:
As it is shown in the screenshots the name of the file already ist displayed in the top bar of the editor. I can assume it is not elegant to have the name twice. So keep the name out of the note.
A macro is just a small automation script to chain commands. Everything I’ve described is trivial to do with Shortcuts. It was exactly my capture system in Obsidian.
This is something I’ve been waiting for.
  1. Offer a more traditional ā€œlibraryā€ setup: create workspaces (single or multiple) containing folders of Markdown files that can be edited, searched, and interconnected.
Feature request: open arbitrary folder as a ā€œworkspaceā€
Panda edits standard MD files and links to external files but also be able to have something like a .textbundle file so that you could copy that file anywhere and the attachments stay with it.
Second that
Also, how can I pre-order?
This is looking really promising!
I’ll second the idea of pinned folders or files, to keep them at the top of the workspace.
Also, Bear’s Quick Open feature would be a nice addition.
This is actually better than Bear if you don’t mind me saying so, and better than iA Writer which is what I use for long texts. I love :heart: :heart: :heart: :heart: the backlinks panel!
When can we test it? :grin:
I wanna take this in a bit more, but man, I am liking where this is headed. This looks incredible!! Sheesh! Definitely looking forward to this!
I love Panda,
Because
  • For file operation, there is Finder, which is the standard UI of macOS, so I don’t need the app’s own Explorer. → :wink: Default Folder X
  • It’s lighter than anything.
  • I think best, cut from editor pain of Bear.
I’m happy can import theme from Write.as
So happy I happened to visit the community forum. I would have never known. This looks incredible. I just downloaded Version 1.0 (3147). Is that the most recent version as I’m not seeing a sidebar?
This Panda version was the alpha for Bear 2.0 beta, mainly testing and debugging the new editor, that was developed from scratch. It was resurrected recently on Mac, due to popular demand.
What we are eagerly waiting for now, is a new Panda beta as a separate file-based product, using the same editor as Bear 2.1.
Thanks for the clarification.
  1. Workspaces are awesome. I would use this all day to separate businesses I run vs client work/projects.
  2. Love the sidebar. It’s perfect.
  3. Please envision the most important part of a writing app for me: ability to share my files simply for read access (not collaboration). I know you’ll probably say just export or maybe drop in a Dropbox folder and share that way. But how can we cut down the steps and make it dead simple. I’d give up two other apps just to stay in the Panda family.
  4. Make it easy to swap out a default theme for our own. Your typography is beyond excellent but I want my own colors.
This looks really great and seems like it would be a perfect compliment my markdown editing needs.
Personally I love and use bear for everything. But for taking notes at my job I would use Panda as it fits the restrictions of my work computer and allows keeping my markdown files on disk and separate from the personal files.
Looking forward to trying this out.
Me too. I’m not a fan of putting files in notes apps as I’ve lost files before. Not in Bear but other programs.
However, I like the idea of keeping information on a topic together. I have folders for projects that I do with various files such as spreadsheets, word processing, etc and would be super nice to have markdown files in these folders then be able to edit with Panda thus keeping information in 1 spot.
I think Panda would honestly be great for writing novels. I don’t mind having stuff like that in Bear, but to have it all in folders in plain markdown files would be ideal. You’ll definitely give iA Writer a run for its money.
I agree. Certainly now that they’ve added a not-so-well-working AI and other rubbish instead of following through on their initial plan to make iA Writer more of a knowledge tool. Not that I would use it instead of Panda 2 – writing markdown is OK, but having to constantly switch between the editor and a preview panel to see your text formatted is not very efficient, let alone if their templates don’t offer what you need, and you need to switch to Marked 2 instead…
That’s absolutely my planned Panda usage — long-format writing and project file organizing. Can’t wait!
