Pasting over existing link - label does not update
  • Lettera Version: 4091
  • macOS Version: 26/5/2
  • What were you doing: I typed in a link called original.com, then selected it and pasted a new link called pasted.com
  • What feature did you use: Command V
  • What happened: The link target changed to pasted.com, but the link label remained displaying original.com (see attached image)
  • What did you expect to happen: I expected the link label to change to original.com
I don’t think it’s normal behaviour. When I use Word, it changes the both the link and the label.
You may be confused because I uploaded a screenshot of the dialog box. I didn’t use the dialog box to do any editing - I only showed that to illustrate that the link and label were different.
The exact steps I used were:
  • Open a Lettera document with a URL in it (the “original” URL)
  • Go to Safari, select another URL (the “pasted” URL) and copy it using Command C
  • Go to Lettera, select the existing URL and paste over it using Command V
  • Observe that the Lettera document now has a URL that has a label with the original URL but a link of the pasted URL
I just tried it in Pages and it works just like Word.
As I said above, I’m not using the dialog box.
