PDF drag'n'drop seems not to work
Operation system: Mac OS Sequoia
Web Browser: Safari.
Dragging a PDF to a note shows a kind of “link”. But it does not work. Clicking on the link does not produce any response. The PDF integration looks different in the “Inventory notes” section, and clicking on the corresponding entry downloads the PDF.
What were you doing: Drag and Drop different PDF’s from the finder
What happened: A kind of Link was created, which looks different to the PDF integration in the existing notes
Hi, well spotted! This was indeed a bug and will be fixed in the next release.
:+1: Thx, for the quick response
(post deleted by author)
I have a similar issue with images. I think it has something to do with the name of the file, because if I change it, the problem is solved. In this case, the name of the image (png file) was “imgs%2Fapp%2FLPQTP%2F38mvTsl73w”
Captura de pantalla 2025-09-27 a la(s) 13.12.54
Hi, yes that’s a good point. That filename is a full path rather than a filename (it has “/” in it). I am honestly not sure how the web app will respond to that. I’m adding it to the things to check.
Oh sorry for not being clear enough, in my case it happens in the MacOS app (all the latest versions). I don’t use the web app.
