Bear Version:
- 3.02
OS Version:i
- OS 27.01
- iPadOS 27.01
- Golden Gate 27.01
- Attaching a PDF to a new new note
- Attaching a PDF to an existing note
- Menu Bar attachment option
- Drag and drop
- Apple Share
- Attachment Failed
- Bear created a Link instead
- PDF Name used as link title
What did you expect to happen
- PDF file to be attached as usual
Other
- I tried other PDF files with same result
Screenshot of Link
I think the issue here is with the file name, in particular, the ~20% and "Flexing".
Do you mind sharing the file here or via DM?
Renaming the file fixed the problem. Thanks heaps! ![]()
