Renaming attachments
  • Bear Version: 2.7 (14262) Beta
  • OS Version: Mac and iOS
I was trying to rename an attachment and it does not change the name. It used to work fine. This is on macOS and iOS.
Same! Also on both MacOS and iOS and same versions.
I have the same issue. iPadOS on version 2.7 beta also
Thanks for reporting this issue. We are investigating, and we’ll fix this bug as soon as possible.
