2.0 (10936)
MacBook Air M1
Renaming a tag
Tag edit
When I edited a tag and renamed it then it created a duplicate tag in the side view. The duplicate is not expandable. When I exit Bear 2 and relaunch then the duplicate tag is no longer shown in side view. Effective workaround in place.
Edit a tag, rename the tag, and do not see another tag with the same name.
