MacOS 2.0.2
Importing a document from craft with quotes
Import from Textbundle
I exported a multi-line quoted document from Craft, which looks like this:
The code for which, in the Textbundle, is this:
# Test
> This is a multi line quote
Which looks normal in craft
But abnormal elsewhere
In Bear, the imported document looks like this:
If I select before “Which” and press the space bar, the alignment for everything else is resolved:
I imagine this is a bug in the way Craft renders their textbundle, but it also seems that Bear does not “cope” with the render in a way I’d expect. I’d think that the second two lines would simply have no quotation mark, rather than “bleeding” over it.
Rendering to behave in a more predictable way.
