Resizing Images
Call me pedantic. I like my Bear looking orderly so I’m using images usually at a uniform size (500x500) andso far, I just dropped them onto the page and then fulled the resize handle to the minimum. That way all the images were just the right size to look at and, importantly, the same size. Now, in 2.4, I suddenly can pull them in to be much smaller. That’s not a problem, but it means I have no real control to make them all the size I used to do, other than by eye. I thought it might be cool to have a bit more precise control (maybe by holding ‘shift’ or ‘tap’ to resize in steps?
