- Bear Version: 2.6
- OS Version: 26
- What were you doing: Shift + >
- What feature did you use: Bear Note editing screen
- What happened: |
- What did you expect to happen: >
I’m not sure what you mean. Do you get | instead of > when you hit shift+< ? If this is the case, is this happening only in Bear?
Afternoon correct, and yes only in Bear.
macOS Tahoe Mac Studio Max M1 64GB
Cheers!!
`RobD…
Shift+. to get a > this is output |
Cheers!!
`RobD…
Only at beginning of line, and only Bear
Oh I see. I markdown > at the beginning of the line generate a block quote.
Solved need space before attempting as activates callouts, otherwise…
