- Bear Version: 2.5.1 (13605)
- OS Version: macOS 15.3.2
- What were you doing:Using the ⌘⌥↑ shortcut to move some lines of text up in a note. Partway up the note was a code block of multiple lines.
- What feature did you use: Standard Keyboard shortcut to move text
- What happened: When the text hit the code block it moved into the code block when it should have. Then one more use of the shortcut and it moved up one more line into the code block then it would not longer move up. I could still move the text back down and out of the code block.
- What did you expect to happen: I expected the selected lines to keep moving up in the document until I hit the desired location.
- This is very repeatable. I could do it in multiple notes with code blocks and it happens if I just put the cursor in a single line, select a line, or select multiple lines.
Apparently, I can’t reproduce the issue. Any chance you can share a note reporting this problem? You can also set it to me via private message here on the forum.
