Keyboard Shortcut for Move Paragraph does nothing on iPadOS 26
  • Bear Version: 2.6.3
  • OS Version: iPadOS 26
  • What were you doing: Trying to use Keyboard shortcut to move paragraph
  • What feature did you use: Keyboard shortcut OPT-CMD-Up/Down
  • What happened: The keyboard shortcut OPT-CMD-Up/Down does nothing on iPadOS - I’m unable to move text using a keyboard
  • What did you expect to happen: Line or Paragraph should ,I’ve Up / Down
I don’t seem to be able to simulate this issue. Do you mind trying to reboot your iPad?
If you are still running iPadOS 26.0, try also to update.
  • What did you expect to happen: Line or Paragraph should move Up / Down
I have rebooted and am already on iPadOS 26.1 - I get no line or paragraph move
