Up arrow navigation stops at headings with blank lines above
Operation system: Windows
Web Browser: Firefox
What were you doing: Moving cursor upward using the up arrow key
What feature did you use: Editor
What happened: The cursor stopped moving when it reached headings that had a blank line above them, regardless of the heading level. This behavior doesn’t occur when using Chrome.
What did you expect to happen: The cursor should continue moving upward
Indeed. Thanks for reporting!
