Operation system: Mac OS 15.3
Web Browser: Firefox 135.0
What were you doing: Trying to edit my notes
What feature did you use: Web editor
What happened: Weird behavior on key press
What did you expect to happen: Normal expected response on key press
Hi,
While trying to edit the notes, I discovered the following issues:
- Pressing the arrow key “Up” always skips any empty line in between. I’m not sure if this is intentional. I would expect for it go to previous line even if its empty.
- Pressing the “Delete” key to remove character on left at the end of a line also seems to remove empty lines from below.
Here is a screen-capture of these behaviors:
