Shortcut search errors
I am running the latest beta (2.3.6 - 13027). I am getting lots of errors when searching with shortcuts.
For example, the search:
#journal/2023/11/20
generates an error
The search works fine when inside Bear. Just Shortcuts. It was working fine before but on the last update is when it started.
ouch. Are you experiencing this issue on iOS but not macOS? Can you please tell me how many notes do you have?
Just iOS (I only have iOS devices). 440 notes.
Where “Text” would be (for example):
#journal/2022/11/21
Thanks. Update 2.3.7 (TestFlight) will be available as soon as Apple approves it.
Please let me know if you still experience this problem.
FYI. Just installed the 2.3.7 update and it works great! Thank you.
Hello, unfortunately I have the exact opposite problem : “search notes” command worked within Bear 2.3.6 (one caveat though : I had to assign a limit to the number of results). When I installed Bear 2.3.7 via TestFlight, it broke completely : I keep getting an error message (“can’t communicate with the app”), even when I assign a limit to the number of results. Maybe there is a problem with my syntax ?
I tried your example and thought maybe having the # at the end may be an issue but it did work with or without it at the end.
I do wish Shortcuts had some type of error logging so that additional information could be sent to the devs.
Thanks a lot for your help ! Unfortunately I get the same results with or without the second #. Maybe it has something to do with installing a beta version (TestFlight, 2.3.7) on top of a regular one (2.3.6). Maybe I should try to uninstall the regular one first ?
By the way, as a total beginner with Shortcuts, I completely agree with you regarding error logs. And thanks for your amazing work on Daily Notes, I stole a bunch of ideas from you :wink:
Good idea on installing the TestFlight version fresh but I did what you did by installing it over the official one (ie. did not uninstall official one first).
Does seem strange. If my memory is correct, I believe a few minor versions ago there was a similar issue with the search in Shortcuts, but they fixed it and then it cropped back up in 2.3.6.
Strange indeed ! Thanks for your input, I will wait for the next stable version and skip 2.3.7 for the time being !
How many notes do you have in your Library?
Hello ! I have exactly 2849 notes.
I am experiencing this issue on iOS and iPadOS. I haven’t tried to install the Beta on MacOS, but I’ll check as soon as I can.
Thanks for your help, anyway !
