Slow Performance
2.0 (11504)
Scrolling through a note
None
Rainbow wheel every few scrolls.
Smooth scrolling without any (or very little) lag.
Comments
The note in question did have a very large PowerShell code block but it did make Bear painful to use in that moment. I’m concerned that as I get a more and more notes in Bear I’m going to hit this issue more and more.
Since posting this I’ve also experienced significant lag when typing text in another note. The note has 1,605 words (21,512 characters / 371 paragraphs).
If I open a blank note and type then it’s fine.
I’m on a MacBook Pro with the M1 Max chip and 64GB of memory so it can’t be a resource issue.
