- Bear Version: iOS 2.3.5 (12991)
- OS Version: iOS 18.0.1 on an iPhone 16
- What were you doing: Opening the Statistics/ToC/Backlinks popup by tapping the i in a circle, then attempting to scroll down to see all backlinks
- What feature did you use: The Statistics/ToC/Backlinks
- What happened: The popup vanishes as soon as I made a scrolling gesture. Not when I just tap it, only when I drag up or down on it
- What did you expect to happen: I expect to be able to scroll, and I expect the popup to remain in place
This is a reproducible bug. It happens with every note.
There is a bug report from long ago that’s similar, but the bug is live.
