Symlinks wrongly displayed
  • Lettera Version: 1.0.0
  • macOS Version: 26.5.1
  • What were you doing: Opened a folder
  • What feature did you use: Nothing
  • What happened: As you can see from the picture, the list of files/folders displays 2 files called “AGENTS.md”. In reality, one is a symlink called “CLAUDE.md”, that points to another file called “AGENTS.md”
  • What did you expect to happen: 2 files, CLAUDE.md and AGENTS.md. CLAUDE.md should show the fact it’s a symlink of another file (possibly also when opening it, an alert indicating what is the source and opening it, instead of letting the user edit it directly)
ditto.
In fact in my case opening a discourse/discourse project lists 4 instances of AI-AGENTS.md file.
Version 1.0.0 (3980)
macOS 26.5.1 (25F80)
