TagCon not working on MacOS 26 beta
  • Bear Version: 2.4.6 (13532)
  • OS Version: 26.0 DB3
  • What were you doing: Changing the TagCon for an existing tag
  • What feature did you use: Edit tag
  • What happened: The TagCon dropdown wouldn’t open; the TagCon reverted to the default. Another computer running MacOS Sequoia worked correctly.
  • What did you expect to happen: The TagCon window to open as it does on Sequoia
NB: I submitted a report to Apple via Feedback Assistant
Thanks for reporting this, but mind that we can’t provide macOS/iOS 26-specific fixes until the developer tools provided are out of beta.
