- Bear Version: Version 2.7 (14142)
- OS Version: 26.3
- What were you doing: used mcp to edit some tag structure
- What feature did you use: tags editing
- What happened: the tags were created, in the notes correctly, but they dont show when searched or in sidebar
- What did you expect to happen: them to show in search and in sidebar
What MCP have you used?
This one is there others?
HI there! I am the maintainer of that MCP server. I could not reproduce this, but Iβd like to dig deeper anyway.
Here is how I tested it:
OS: 26.3
Bear app: 2.6.7 (I donβt see the 2.7 update in the App store, do you use beta?)
- Test A β bear-create-note with tags (conventions ON): database indexed, sidebar visible
- Test C β bear-add-tag / reporter's path: database indexed, sidebar visible
- Test D β bear-add-text with inline #tag: database indexed, sidebar visible
- Test E β bear-add-tag to existing parent: database indexed, sidebar visible
Test E specifically targeted your scenario: adding a subtag to a parent that already has children. It also worked.
@trix180 can you please let me know how to get the 2.7 version? Is it a beta one?
Yes, version 2.7 is currently available via TestFlight
Test Results with Bear 2.7 from TestFlight
- Test 1 β bear-create-note with tags (conventions ON): database indexed, sidebar visible
- Test 2 β bear-add-tag on plain note (reporter's path): database indexed, sidebar visible
- Test 3 β bear-add-text with inline #tag: database indexed, sidebar visible
- Test 4 β bear-add-tag adding sibling to existing parent: database indexed, sidebar visible
@Angel101 can you please try installing the latest version of the extension/mcp from here https://github.com/vasylenko/claude-desktop-extension-bear-notes/releases/tag/v2.7.0 and try using it for a while to see if the problem still persists?
MCP server does not make direct DB writes; all writes go through the Bearβs native x-callback API β X-callback-url Scheme documentation
yes! I will download the latest version and lyk if it happens again.
