TestFlight Summer cleaning
Hello beta testers,
We have noticed some people currently subscribed to Bear’s macOS and iOS TestFlight are not testing the latest builds based on the AppStoreConnect data.
We intend to remove the testers with low app sessions by the end of this month to make room for other people willing to actively test new builds.
If you are using or recently used the TestFlight version of Bear iOS and macOS you don’t have to do anything. If you didn’t and you want to remain a tester, use both versions of the apps this month.
Unfortunately, the data doesn’t provide a precise metric, and it’s possible some will be wrongfully removed. I’ll post here when we start the cleaning so we can re-integrate people who still want to have access to TestFlight.
How do I get my name on the list of potential testers once there’s some space in the pool for new users?
Maybe this comment is enough? :wink:
Would like to join Beta too, but how?
I would test macOS iPadOS iOS. I never asked because I thought it was full.
@trix180
My testflight is not updating. Am I still on the list? Testflight shows 2.5
I am on iOS26 PB2
I would also love to join the beta!
You are but release 2.5.1 is not available on TestFlight
Hi, I hope I could join the list of TestFlight. Thanks.
As announced, we removed the inactive testers from Bear’s macOS and iOS TestFlight program.
If you have been removed but want to rejoin, or you just want to have access to the beta, write me a private message here on the forum indicating an email I can use for TestFlight.
