ToC - some header levels greyed out
  • Lettera Version: 1.0.0 (4458)
  • macOS Version: 26.6.2
  • What were you doing: reviewing ToC panel
  • What feature did you use: enabled ToC panel
  • What happened: only H1 & H2 lines were visible
  • What did you expect to happen: All Headers would be visible and indented appropriately
My H3 & H4 headers were not visible but the entries are presented and indented but the text is not visible in the OS Light mode. In dark mode, the text is visible.
Light Mode
Dark Mode
thanks -tom
