Shortcuts for export and print of Panda notes
Hi
lovers,
While waiting for print function in Bear 2.0 beta/release, I made a couple of shortcuts to export/print notes created in Panda alfa.
The first one converts .panda files and opens them in Ulysses for styled print/export there. Supports Panda’s resized images, PDF preview and footnotes.
The second one simply extract .panda files and imports it into current Bear-note app, and you can use export or print from there.
Neither of them supports proper table formatting, so we have to wait for Bear 2.0 beta for that – I hope …
Runs in Shortcut app on MacOS Monterey, iPadOS and iOS.
Test it out and modify as needed.
Have a good day or night, wherever you are ![]()
