Operation system: MacOS 15.6 and Tahoe DB3
Web Browser: Safari
What were you doing: Attempting to create a duplicate note
What feature did you use: Right-click on note to pull up menu
What happened: Duplicate option wasn’t on the dropdown list
What did you expect to happen: Duplicate option to appear on the list
Hi, thanks for the feedback. I can confirm the duplicate note action will be added to Bear Web in a future release.
Thank you for the update.
Any update on this? Duplicating notes in the web version would be really useful. I’m assuming there’s some kind of technical issue that makes this harder to implement or it would have arrived by now. I’m curious to know more if you can comment
