Duplicated notes in bear web
Operation system: Windows 11 24h2
Web Browser: Google Chrome
What were you doing: I’m switching from tag to tag
What feature did you use: Basic usage of bear web
What happened: Some notes are duplicated
What did you expect to happen: To show only one time each notes
Bear web is great !
I’m facing a problem right now, every now and then, when i switch from a tag to another, it show some (sometimes all) notes in that tag duplicated. When i select a duplicated notes, both are selected with the red line, like if they are the same note (which they are).
I don’t know if i explained it enought or not.
If you need clarification, please ask me.
Have a good day
Hi and thanks for the feedback. That’s very interesting (and concerning). We’re currently trying to replicate this issue and will keep you posted on this thread!
Just about to report this issue!
I’m using safari on MacOS 15.1
Hi
i’m using Chrome Version 136.0.7103.114 (Official Build) (64-bit)
on windows 11 Version 10.0.22631 Build 22631
To replicate this issue, you can try change between tags.
The issue appear when i’m change between tags.
