Testing version: Version 2.0.7
What were you doing: Using tildes (~) in plain text to mean approximately
What feature did you use: Plain text
With the following input text (reflecting my real use case):
Lorem (~2 mb)
Ipsum (~4 mb)
Bear is treating the tildes as start and end markers for an underline, leading to this output:
Lorem (<u>2 mb)
Ipsum (</u>4 mb)
What did you expect to happen: I expected no markdown formatting to apply.
User-possible remedy: I can reformat my text as a bullet list. This seems to stop the underline pattern search. But I’d prefer to not change my writing content.
Drive-by parser suggestion: Maybe the underline pattern search can be tweaked so that a line break ends the search if the second tilde isn’t followed by white space.
Edit: Originally wrote “strikethrough” when I meant “underline”
