I couldn’t find a feature request page so hopefully this is the correct spot.
Is there any way to have the web clipper link & tag appear at the top of the document, under the headline? Currently, it shows up way at the end of the clipped web page.
no, the tags and link positions can’t be changed at the moment but thanks for your feedback.
Regards.
Hi Danilo,
always when you devs say “at the moment” that rises the hope it will or can happen in (near) future. ![]()
I asked here for placing special tags (not written manually inside the text) at the top of a document rather than at the bottom. Arey there any plans for that or do you have at least discussed that?
