What "record shortcut" for "create a new note" in settings do?
On mac, in the settings popup, there is an option to “record shortcut” for “create a new note”.
How is this different than using command+N to create a new note (which I believe is default)?
It’s a global shortcut, accessible from any application. Using it brings Bear to the front and creates a new note.
I understand. I will not have to set it just to test it now.:sweat_smile:
Thank you
