Request: Quick Entry
I want to use a keyboard shortcut to invoke a small pop-up window that I can type a note into, and then when I press Command+Enter it saves it, and the window disappears. I can’t find a way to do this now without bringing all of Bear into focus. I just need a little quick note applet. Please look at how Things has a quick-entry feature for inspiration.
I have created something in that line as a shortcut.
This opens a new note in a floating window with the tag “draft”. On Mac you can bind it to a keyboard shortcut. Granted, uw will not go away that easily, although you could press cmd+w.
but I would love an Apple Quick Notes feature for Bear.
