Operation system: Windows 11
Web Browser: Edge, Firefox, Vivaldi
What were you doing: Attempting to create new note via shortcut
What feature did you use: Shortcut to create a new note
What happened: Nothing
What did you expect to happen: New note
Feedback: Unsure if this shortcut is currently implemented or still pending.
bru
2
Hi, thanks for the feedback. The shortcut list published in the FAQ is indeed misleading; we’re going to fix it and will keep you posted here.
I appreciate it, thank you for the prompt response!
bru
4
We shipped the shortcut as ctrl+alt+N, and updated the documentation, thanks again for your feedback!
