Wikilinks Autocomplete is very slow
  • Bear Version: 2.3.10
  • OS Version: Sequoia 15.2
  • What were you doing: Trying to type out a wikilink
  • What feature did you use: wikilink autocomplete
  • What happened: The autocomplete search is very slow
  • What did you expect to happen: it should be fast!
This happens on iPad as well.
If I start typing a wikilink ( [[A ) Bear tries to autocomplete for me, showing a list of options. Frequently when doing this each letter I type takes about a second to even appear as the list updates. So if I type the link fast, for 10 characters it might take 5-10 seconds for it to catch up with my typing. I imagine that maybe the indexing method isn’t tuned well enough or something – I do have a lot of notes (12771 of them)
Thanks!
