What is your fastest method to get to the top of the notes library?
- If I’m way down into my Notes,
Command Option 1doesn’t work by itself - If I press
Command Option 2or a different library choice number thenCommand Option 1, it will take me to the top of my Notes 95% of the time. I say 95% because sometimes I have to press the combo twice for some reason but this is what I’ve been doing for a while.
Do you have another workflow? Is there a keyboard shortcut I’m missing?
iOS Bonus Tip: Inside a note, two finger swipe up or down will bounce you to the top or bottom of your note. You’ll feel haptic feedback when it triggers.
