A few Shortcut ideas!
The combination of Bear + Shortcuts is incredible, I’ve had so much fun setting up templates and automations and for the most part it’s worked beautifully! There’s been a couple of cases where I wish I had access to a certain shortcut action, so I figured I’d share the ones I’ve come across
  • Get Pinned notes
  • If Note Section is [Todo], [Untagged], [Archive], etc (In “If” blocks, this would allow for filtering notes by whether they’re in @todo, @archive, etc)
  • Get notes in Section (This would return all the notes in a certain section)
  • Graceful failure of Get Note (If Note doesn’t exist; create it, ask for input, continue, stop, etc)
