GROUP tags visually and freely order in stead of using nesting for the wrong purpose
We should be able to GROUP tags in SECTIONS visually (just to unclutter the TOC) in stead of having to rely on nested tags to mimic a folder structure, the latter totally missing the point of thinking in tags, which was supposed to be the core business of Bear, isn’t it?
I do not want folders, I only want a clean, folded TOC with a strong emphasis on what’s 1.functional labels, 2.active workbench (areas, projects if you want) and 3.vault/resource/tools whatever you like to call it, out of sight (so at the bottom) until you need it
I want to be able to decide where in the TOC I put my tags and if possible have some space where I want it in between them
Don’t advise me to use numbers please
Now I do this:
(pinned tag) in progress
(pinned tag) next
(pinned tag) unfolding
etc.
and then I use a tag
just to create kind of an empty space between functional and “active content”-tags ( ! )
#project/project1
#project/project2
etc.
and
#study/bass
#study/daoism
#study/orchestration
etc.
and as a third “main section”… (can’t manage to use an emoji to create empty space here though because that is ASCI-alphabetically impossible)
#tiles/art&design
#tiles/music
#tiles/producing
#tiles/admin
etc.
followed by
#projectarchive
#templates
using the Apple symbol because Bear puts it at the end when sorting the TOC
So what am I doing here? Using a lot of cumbersome tricks to be able to make Bear visually “my own”. Another two:
I use “Tiles” instead of Resources just to avoid that my (passive) Resources are in between (active) Project and Study tags
When we would be able to create sections in the TOC, I wouldn’t need al that nesting, or I could use nesting to go deeper (of which I stay far away now to avoid too many levels)
Solution:
- let us create sections through using groups and spaces in the TOC, purely visually (please, how hard can this be?) which would be sufficient but nevertheless crucial for avoiding friction
- let us decide ourselves in which order and which section we place our tags in the TOC
I think my “thinking in tags” and my own, thoroughly conceived personal methodology (no thank you influencers who para-switch every few months and never gtd) should be able to exist in Bear without friction. If Bear can’t do it, who else can?
